Spider valve hd100 cabinet
Need some help, don't know much about this, just purchased a spider valve hd100 that I want to connect with a line 6 cabinet 4x12, 150 watts per side, 8ohms, can I do this or do I need another cabinet?
The cabinet should have two input jacks, make sure you connect both the left and right amp outputs to the cabinet (using speaker cables, not instrument cables) - connecting only one will imbalance the amp and eventually cause damage.
Ok thanks. Sorry to bother u again, got another question. When I play it loud it sounds like it's clipping, would it be the amp head causing it on the speakers cause it's too much power ? Or could there be something wrong with the head itself. When I plug in my spider iv hd150 combo to the cabinet it sounds fine, doesn't clip...
