Blubarb Posted May 7, 2015 Share Posted May 7, 2015 Spider Jam's memory, as I have come to find out, doesn't hold much (in terms of songs saved as .wav files) tranferred from an SD card to the recordings. Not sure of available memory size (let me know if you do know). Right now I have only fit 5 relatively small recorded music tracks/files saved into SJ. I am wondering if there is a known way to play selected recordings from the SD card directly. Cheers John Quote Link to comment Share on other sites More sharing options...
gary9605 Posted May 8, 2015 Share Posted May 8, 2015 Yes you can...... when you power up your Jam just press the DRUMS button on panel.... then with the selector wheel.. move it over to SD , the use the Knob to scroll down to pick whatever you have saved on it. Quote Link to comment Share on other sites More sharing options...
Blubarb Posted May 8, 2015 Author Share Posted May 8, 2015 Thanks Just Startin'. When I follow that process I get the message "Internal disk full" followed by "insufficient space". Quote Link to comment Share on other sites More sharing options...
gary9605 Posted May 9, 2015 Share Posted May 9, 2015 Sorry, not seen that before........ hopefully someone else can assist you with that. Quote Link to comment Share on other sites More sharing options...
wiseman1965 Posted June 1, 2015 Share Posted June 1, 2015 I guess when you are playing a song from the sd card, it is probably copied temporarily to the internal memory. When the internal memory is completely full, you can't do that. Have you tried to free some of the internal memory and then play from the sd card? HTH Quote Link to comment Share on other sites More sharing options...
