lemon Posted May 7, 2015 Share Posted May 7, 2015 Hi! Today I had a big problem with my XD.-V70 microphone. Connection between transmitter and receiver was perfect, but I had no audio signal on the receiver. As I have also a shure SM58 wireless handheld I tried the following: I took the Shure's capsule and put it on the Line6 transmitter - audio worked perfectly. Then I tried to put the Line6 capsule on the Shure transmitter - and it worked also!!! Well, I really cannot understand why the Line6 capsule won't work with the Line6 trasmitter, maybe anyone can explain it to me? Thank you very much and greetings from Italy! Andy 1 Quote Link to comment Share on other sites More sharing options...
lemon Posted May 7, 2015 Author Share Posted May 7, 2015 Ok, now things have changed as no capsule will work on the XD-V70 handheld anymore, so there is a problem with that part. Maybe it's a known problem and how can I handle it? Thank you again Andy Quote Link to comment Share on other sites More sharing options...
Reason413 Posted May 20, 2015 Share Posted May 20, 2015 sounds like you damaged one of the pogo pins inside the mic, unscrew the capsule and take a look... Quote Link to comment Share on other sites More sharing options...
