Brain2Me2 Posted May 7, 2015 Share Posted May 7, 2015 Just filled a support ticket about this, but gigs are coming up this weekend and I really need this. Yesterday I was at a rehearsal and was setting up my L2t to run some backing tracks through the RCA inputs. Connected everything, and played a track and everything was sounding great as always. Went outside for about 5 minutes and came back to check the setup with the drummer, all of the sudden I only hear a whisper from what is playing coming only from the tweeter, and nothing else. Checked all connections, disconnected everything...tested on every input with a mic with different cables, also with my POD, and the same...very faint sound only coming from the tweeter. Tested at home before writing this, and same result. I'm sure there wasn't foulplay from anyone, because I was the only one there setting up before the drummer arrived. I did notice today that the front led has both the white and red colors lit at the same time, maybe the limiter is stuck somehow, someway. Any ideas, maybe a cable is loose or disconnected inside. Thanks! Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 8, 2015 Share Posted May 8, 2015 Just filled a support ticket about this, but gigs are coming up this weekend and I really need this. Yesterday I was at a rehearsal and was setting up my L2t to run some backing tracks through the RCA inputs. Connected everything, and played a track and everything was sounding great as always. Went outside for about 5 minutes and came back to check the setup with the drummer, all of the sudden I only hear a whisper from what is playing coming only from the tweeter, and nothing else. Checked all connections, disconnected everything...tested on every input with a mic with different cables, also with my POD, and the same...very faint sound only coming from the tweeter. Tested at home before writing this, and same result. I'm sure there wasn't foulplay from anyone, because I was the only one there setting up before the drummer arrived. I did notice today that the front led has both the white and red colors lit at the same time, maybe the limiter is stuck somehow, someway. Any ideas, maybe a cable is loose or disconnected inside. Thanks! That sux...this is the second limiter issue posted in as many days... Quote Link to comment Share on other sites More sharing options...
