jaredbrown85 Posted May 14, 2015 Share Posted May 14, 2015 Is anyone else having an issue with the tuner freezing up. Requires getting out of the tunner and going back in. It is getting to the point where is about freezes on every string. Had mine for over a month, this is a new issue. A reboot cycle tends to help, but only for a while. Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 14, 2015 Share Posted May 14, 2015 Haven't heard of that one before- can you use the tuner on the Firehawk OK without the app running? If so, I would lean towards a re-install of the app. Quote Link to comment Share on other sites More sharing options...
jaredbrown85 Posted May 15, 2015 Author Share Posted May 15, 2015 Bluetooth not connected with this issue. Quote Link to comment Share on other sites More sharing options...
bond19 Posted May 15, 2015 Share Posted May 15, 2015 Ok, well make sure you have all your presets saved in the app, then do a system restore (you will lose all settings, as it puts it back to factory state). Quote Link to comment Share on other sites More sharing options...
jaredbrown85 Posted May 15, 2015 Author Share Posted May 15, 2015 Yeah I'll just hold out for 11 if the issue persists then I'll pursue that Avenue. Was mostly curious if anyone else had this problem. Quote Link to comment Share on other sites More sharing options...
TriPPleX Posted May 16, 2015 Share Posted May 16, 2015 I've had the lockup on tuning also, just once. I've also had the outputs completely go mute while adjusting with the knobs, had to reboot to get the output back on. Can't happen during a show. Quote Link to comment Share on other sites More sharing options...
lknick5150 Posted July 4, 2015 Share Posted July 4, 2015 I haven't had a issue with tuner locking up but have used firehawk at band practice and if drums or other other instruments are playing loudly in room.....firehawk tuner seems to get disrupted and cannot tune correctly....becomes useless unless room is quiet..... Quote Link to comment Share on other sites More sharing options...
