gscott Posted May 30, 2015 Share Posted May 30, 2015 Hey guys need help. Loving the Firehawk, now attempting to do some recording into my iPad 4 via the camera connection. I am using Beatmaker 2 and had imported a 16 bit/44.1 MHz wav file from Dropbox. Played the file before hooking up FH, sounds great. But when I plug in FH via lightning/camera connection kit, the file plays faster and higher pitch. Sounds like a bit rate thing, any advice? Quote Link to comment Share on other sites More sharing options...
stevekc Posted June 9, 2015 Share Posted June 9, 2015 am using Beatmaker 2 and had imported a 16 bit/44.1 MHz wav file from Dropbox. Played the file before hooking up FH, sounds great. But when I plug in FH via lightning/camera connection kit, the file plays faster and higher pitch. Sounds like a bit rate thing, any advice? The Firehawk connects to IOS devices as a 24-bit/48kHz audio USB Class Compliant Device You may need to convert 44.1kHz audio files to 48kHz type? Quote Link to comment Share on other sites More sharing options...
