bond19 Posted June 2, 2015 Share Posted June 2, 2015 Just got a Roland KC-350 amp. Anybody try one of these with the Fireawk yet. It is supposed to be a full range stereo amp. I would be curios on how the best way to hook it up would be, as it seems to have a fair bit of input options. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ozbadman Posted June 2, 2015 Share Posted June 2, 2015 I am a big fan of Roland products generally, but I have found the KC amp series very underwhelming. Underpowered, no bass, lots of midrange. I have tried the KC-350 and KC-550 and was very disappointed for use as a FRFR amp given Roland's excellent keyboards and V-drums. Hell, they even broke up (distorted) fairly easily, which I don't expect for a FRFR amp. I still have a KC-110, but use PA's, or a DT-25 or Blackstar HT-40 if I'm OK with a guitar amp, or would recommend a better FRFR amp. YMMV. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted June 2, 2015 Share Posted June 2, 2015 I think you need 2 for true stereo? It only has one speaker Quote Link to comment Share on other sites More sharing options...
bond19 Posted June 2, 2015 Author Share Posted June 2, 2015 I am a big fan of Roland products generally, but I have found the KC amp series very underwhelming. Underpowered, no bass, lots of midrange. I have tried the KC-350 and KC-550 and was very disappointed for use as a FRFR amp given Roland's excellent keyboards and V-drums. Hell, they even broke up fairly easily, which I don't expect for a FRFR amp. I still have a KC-110, but use PA's, or a DT-25 or Blackstar HT-40 if I'm OK with a guitar amp, or would recommend a better FRFR amp. YMMV. Ok, so you have used the KC-350 with the Firehawk? If so, which hookup yielded the best results? Quote Link to comment Share on other sites More sharing options...
ozbadman Posted June 2, 2015 Share Posted June 2, 2015 Ok, so you have used the KC-350 with the Firehawk? If so, which hookup yielded the best results? Not with the firehawk, no. I was talking about my experience with it generally as an FRFR. In my case, for an HD500 and an AxeFX2. Quote Link to comment Share on other sites More sharing options...
bond19 Posted June 2, 2015 Author Share Posted June 2, 2015 Not with the firehawk, no. I was talking about my experience with it generally as an FRFR. In my case, for an HD500 and an AxeFX2. Ok, can you let me know how you set up for an HD500? Thanks, I have yet to plug into it yet. Quote Link to comment Share on other sites More sharing options...
ozbadman Posted June 3, 2015 Share Posted June 3, 2015 Ok, can you let me know how you set up for an HD500? Thanks, I have yet to plug into it yet. Well, if you only have one, there's no true stereo, so the simplest way is to take a standard 1/4inch guitar lead from the left (or right) side of the unbalanced outputs on the HD500 and plug it into channel 2 on the KC350. (channel 1 is for mono balanced/mic, or use channel 4 if you want extra control over routing in the KC350). The HD500 will automatically combine the two stereo paths to mono if a single lead is plugged into its unbalanced output. Quote Link to comment Share on other sites More sharing options...
bond19 Posted June 3, 2015 Author Share Posted June 3, 2015 I am thinking it will be best on channel 4. I also think that as I will be sending my stereo xlr outs on the firehawk to front of house, through a snake, I will be fine running mono 1/4" into this unit. Thank you for you input OZ. Quote Link to comment Share on other sites More sharing options...
