Sign in to follow this
red888
Can't update AMPLIFi TT firmware from my PC
Trying to use the PC utility to update the firmware, but Windows can't find a suitable driver.
I'm running Win 7 SP2 x86.
Look at the attached picture for the errors I'm getting.
Where is the actual driver? I can try to point it to the actual driver in device manager, but I don't know where it would be.
I searched C:\Program Files\Line6\AMPLIFi Utility for any .inf or .sys files and didn't find any. Where does the installer actually put the damn USB driver?
I uninstalled and reinstalled, but got the same error.
Here is the output of the installation of the utility:
Output folder: C:\Program Files\Line6\AMPLIFi Utility
Extract: AMPLIFi Utility.exe... 100%
Extract: LICENSE-lgpl3.txt... 100%
Extract: LICENSE.LGPL... 100%
Extract: Qt5Core.dll... 100%
Extract: Qt5Gui.dll... 100%
Extract: Qt5Multimedia.dll... 100%
Extract: Qt5MultimediaWidgets.dll... 100%
Extract: Qt5Network.dll... 100%
Extract: Qt5OpenGL.dll... 100%
Extract: Qt5Positioning.dll... 100%
Extract: Qt5PrintSupport.dll... 100%
Extract: Qt5Qml.dll... 100%
Extract: Qt5Quick.dll... 100%
Extract: Qt5Sensors.dll... 100%
Extract: Qt5Sql.dll... 100%
Extract: Qt5WebKit.dll... 100%
Extract: Qt5WebKitWidgets.dll... 100%
Extract: Qt5Widgets.dll... 100%
Extract: QtWebProcess.exe... 100%
Extract: USBUpdater.exe... 100%
Extract: Uninstall.exe... 100%
Extract: d3dcompiler_47.dll... 100%
Extract: icudt52.dll... 100%
Extract: icuin52.dll... 100%
Extract: icuuc52.dll... 100%
Extract: libEGL.dll... 100%
Extract: libGLESv2.dll... 100%
Extract: libusbK.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\L6QmlControls
Extract: l6qmlcontrols.dll... 100%
Extract: qmldir... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick\Controls
Extract: qtquickcontrolsplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick\Dialogs
Extract: dialogplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick\Layouts
Extract: qquicklayoutsplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick\Window.2
Extract: windowplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtQuick.2
Extract: qtquick2plugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtWebKit
Extract: qmlwebkitplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\QtWebKit\experimental
Extract: qmlwebkitexperimentalplugin.dll... 100%
Output folder: C:\Program Files\Line6\AMPLIFi Utility\platforms
Extract: qwindows.dll... 100%
Extract: msvcp120.dll... 100%
Extract: msvcr120.dll... 100%
Create folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Line 6\AMPLIFi Utility
Create shortcut: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Line 6\AMPLIFi Utility\AMPLIFi Utility.lnk
Create shortcut: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Line 6\AMPLIFi Utility\Uninstall.lnk
Running INSTALL_DRV2
Output folder: C:\Users\Meeee\AppData\Local\Temp
----------Installing Amplifi Drivers.----------
Output folder: C:\Program Files\Line6\Tools\Driver2 Archive\Amplifi
Extract: InterposerAmplifiBackEnd.dll... 100%
Extract: InterposerAmplifiBackEnd64.dll... 100%
Extract: L6AmplifiAsio_OnInterposer.dll... 100%
Extract: L6AmplifiAsio_OnInterposer_x64.dll... 100%
Extract: L6ConfigAmplifi.xml... 100%
Extract: l6AmplifiNA.inf... 100%
Extract: l6amplifina.cat... 100%
Extract: l6amplifina_64.cat... 100%
Extract: WdfCoInstaller01009.dll... 100%
Extract: l6Amplifi.sys... 100%
Extract: l6Amplifi_AvsFilter.sys... 100%
Extract: L6Driver2AmplifiControlPanel.cpl... 100%
PLUGINSDIR : C:\Users\Meeee\AppData\Local\Temp\nsi6423.tmp
Execute: "C:\Users\Meeee\AppData\Local\Temp\nsi6423.tmp\DPInst.exe" /PATH "C:\Program Files\Line6\Tools\Driver2 Archive\Amplifi" /C /SW /SA
----------Finished installing Amplifi Drivers.----------
Writing HKLM\Software\Line 6\Current Driver Versions\Amplifi
DRV_VERSION : 1.53
Writing HKLM\Software\Line 6\Driver Install Paths\Amplifi\Install_Dir
INSTDIR : C:\Program Files\Line6
Running INSTALL_INTERPOSER_LIB
Create folder: C:\ProgramData\Line 6\Interposer
Installer Interposer version 22282240, existing Interposer version 23396352
Bypassing installation of Interposer.  A newer version already exists on the machine.
Extract: Line 6 Driver2 AMPLIFi v1.53 Uninstaller.exe... 100%
Writing HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Line 6 Driver2 Amplifi Uninstaller
Completed
I held the tone and tap buttons when powering up, but the utility still cannot connect to it.
Ok, completely uninstalled, rebooted, reinstalled, swapped out the USB cable and now its working.
The utility didn't even ask me to put it in update mode it just updated it. Working great now.
Had I troubleshot this in stages I could have identified the specific problem, but I believe it was the USB cable- I don't think the reboot made a difference.
The cable I tried first had two chokes on it like in this pic: 380-011.jpg
The second I tested didn't have any ferrite chokes like that and it just worked:
Just to be clear I'm not entirely sure the cable I first tried itself was not bad- I didn't test it with another device to confirm.
I am having the same issue. I've tried 3 different usb cables and the seem to work on all other devices. It keeps telling "error/read please do not disconnect or reconnect your usb.
Same issue, except I am using AMPLIFi 75, My first cord was in questionable status as it sat in my garage for years, So I bought another one from Wal-Mart. Im not certian the first was faulty but the new one shouldn't be. It worked enough to show me that my amp was indeed connected by my amp never updates, Read error occurs. Was there anything else I was supposed to download besides the Amplifi Utility. I guess if you got it to work please give me better detail on how you did so.
Mine don´t update firmware. I´ve tried two different USB- cables and ports with LINE 6 updater. It tells that I have connection to Amplifi TT 2.00 but when trying to install new firmware " Firmware update failed. An error has ocurred. Please try again" text will appear. Also with "Apple App update the App only freezes.
Create an account
Register a new account
Sign in
Sign In Now
