Moessieurs Posted August 5, 2015 Share Posted August 5, 2015 Hello. Is there a limit of "lettering" for entering password to Wifi network connexion to a box? My host password for connexion have 26 lettering, i cannot acces to it, seems that the maximum lettering for password for M20d is 16. Anyone experienced more than 16 lettering with succes ? Thank you Quote Link to comment Share on other sites More sharing options...
eklynx Posted August 5, 2015 Share Posted August 5, 2015 wifi passwords are dependent on the router you're using, so I'd look in their manuals/boards, really doesn't have anything to do with the M20d. Quote Link to comment Share on other sites More sharing options...
Moessieurs Posted August 5, 2015 Author Share Posted August 5, 2015 Hello, thank you for your answer, perhaps like i'm French i do not explain enought clearly on the first message to be understood, but yes it have something to do with the M20d. To connect the M20d thru my network, i need to put the network password. On the M20d Step 1 select the network (Livebox), after selecting it, i have this page : I press on the Password "Zone" and i have the second page where i need to enter the password : My safety code have 26 letterings. Of course i have tried several times to be sure that i didn't made a mistakes when i writing the password and done it quietly and not quicly. In this several try, i have check that i can see only 16 symbols on the M20d screen : **************** I have already connect lot of gears on my home network like my Motif XF, Xbox one, of course the ipad for internet, my iphone .... Two options : - the maximum lettering is 16 so i cannot put my complete password and of course cannot acces to my network. - there is no limit of lettering even if i cannot see them on password page, so the samsung wifi dongle do not work thru my Wifi network (even if the dongle seen perfectly my wifi home network). The Samsung dongle (WIS12ABGNX) work fine in Stand Alone mode with the M20d and Stagescape Remote. But, to work like this, i need to change on the ipad, the wifi connexion type in General page and select "StageScape M20d" therefore my wifi home network (Livebox). Connect the M20d thru my Wifi network allow me to not done this step. It's not essential of course, but i will like to know why i cannot done it thru my network. Thanks Quote Link to comment Share on other sites More sharing options...
eklynx Posted August 5, 2015 Share Posted August 5, 2015 Ah, I get it now; I usually use a wired connection to a router so I don't see that page. Not not sure if that is a hard 16 character limit or not. One other thing to check, what wireless security method are you using (WEP / WPA1 / WPA2)? If it's WEP, you might be using a hex version of the key and the ASCII version might be the one needed (it's shorter in length). Quote Link to comment Share on other sites More sharing options...
Moessieurs Posted August 5, 2015 Author Share Posted August 5, 2015 Thank you for your answer, it's a WPA/WPA2 mixed security method. Quote Link to comment Share on other sites More sharing options...
66d35 Posted August 6, 2015 Share Posted August 6, 2015 I would just comment that unless you are trying to prevent some really, really serious and high level hackers (or some national security agency) from getting into your system a 16-character WPA/WPA2 password should be more than adequate - and if I was that worried, I would not be connected wirelessly to anything at all.... Quote Link to comment Share on other sites More sharing options...
Moessieurs Posted August 6, 2015 Author Share Posted August 6, 2015 Thank you, I'm not choosing the password, it was include in the network box and i cannot change it. Quote Link to comment Share on other sites More sharing options...
66d35 Posted August 6, 2015 Share Posted August 6, 2015 Hmmm.. that's a problem! I would think maybe using a different router for the M20D network might be one way around it. Quote Link to comment Share on other sites More sharing options...
