Abitbol
Guitarport and Windows 10 not able to play sound
Hello,
As i have updated to Windows 10, my guitarport is not able to play sound files (via any software like WMP, vlc, ...).
I have updated to last drivers.
(The guitar sound via Podfarm still work.)
Thank you
Finaly I have the solution.
In the Guitarport Advanced properties, I select DVD quality 16 bits, 48000Hz (44000Hz before), and it works.
It seems to be the fix. I'm thinking that a new driver update is coming soon as this seems to be a problem with a lot of Line6 products.
M
im using guitar port and gearbox but i cant get any songs to play. the guitar sounds work but i can not find the options you say can anyone plaease help.
many thanks
I'm happy to see this trick works for most of you !
geeman37, as the Line6 Team said, try this :
"As a potential workaround, some users have noticed that setting the Windows sample rate to 48000 Hz resolves the issue. Go to Control Panel, click on "Sound", click on your Line 6 device, click the "Properties" tab, then click on the "Advanced" tab. In the "Default Format" section, there's a drop down menu which gives you a list of sampling frequencies"
Create an account
Register a new account
Sign in
Sign In Now
