dokav Posted August 7, 2015 Share Posted August 7, 2015 Hello there! ~ Sorry! In this way you questions. Six months ago I was in Japan bought two line 6 stagesource l3t Korea to use. Today, I found the input power is 110V! But South Korea is 220V, since used properly and did not burn, which is why? I do this thing with no problems? my email: dokav@me.com (GOOGLE translation) Thank you very much! Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted August 7, 2015 Share Posted August 7, 2015 Because the input power supply voltage is variable from 110V to 240V as is common in a lot of modern electronic equipement. The power supply will work at any voltage in the range :-) Quote Link to comment Share on other sites More sharing options...
eklynx Posted August 7, 2015 Share Posted August 7, 2015 Lots of manufacturer's make their equipment so they will work anywhere in the world, so it can take anywhere from 110-240V and you can use a standard IEC to local power cable without any transformers. Always look on the equipment though, as I do occasionally run in to some pieces of gear that can't. 1 Quote Link to comment Share on other sites More sharing options...
