HD500 Buttons not working
sjase777
Think i have some non working buttons (looper) on my HD500.
Did the button test - see attached images - one line says '1s' - I assume this means that it is on, and should be on '0' before any buttons are pressed?
Can't seem to find anything online about this test - does anybody know?
If the button isn't working - is it a matter of undoing the allen key of the button and spraying some contact cleaner?
Cheers,
Jason.
I thought the single line of 1's was down to the button used to initiate the test being picked up as the test starts - if you hold that button down the second 1 doesn't change until you release it.
There have been other threads about this, such as:
http://line6.com/support/topic/5056-pod-hd500-unreliable-footswitches/?hl=switch&do=findComment&comment=101709
Everyone that has cleaned their switches has either just sprayed in the top, or has removed the bottom plate to access the circuits.  I did the latter and only used compressed air with good results.
