Sign in to follow this
DelDrago
DT-25 line 6 line 6 link, can i run one dry one wet?
I own an HD 500 & a DT-25. Thinking of getting a secobd DT25 to run in stereo via L6 link.
Is it worth it? Can i run one amp dry & one amp wet? Do I have to run dual tones to use the link?
Anyone running two DT's via link?
Thanks!
I run 2 DT25s via L6 Link. It is very easy, via POD HD500X Edit, to accomplish a number of different configurations. You can run the same amp/preamp to both DTs, send different amps/preamps to them as well. You can send L or R to each or L/R to both. You can run one dry and the other wet. Too many options to list them all actually. I don't think you will be disappointed running two of them. It's also nice if one breaks down that you can still get by with one until the other is fixed. Hope this helps.
