krisbauer Posted September 27, 2015 Share Posted September 27, 2015 Ok so I've been attempting to control the m5 With an xy pad I have installed in my Guitar On my further quest to connect it to actually guitar fx and not just a kaoss pad :) To do this I have also squired an event processor plus from midi solutions. What setting do I need to transmit so fx will toggle on/off ? Here's my info and trials so far From what I understand The m5 uses cc 1 for the expression pedal And cc 11 for fx on off 0-63 bypass/64-127 on My xy pad is currently Set to transmit on channel 1 With x value 0-127 on cc12 And y balue 0-127 on cc 13 Touching the pad send cc 127 And not touching the pad sends cc 0 There is also a hold function that keeps values where last touched while turned on Ok small problem is I can't fully test it because I broke my screen changing the frame around it and have a new one on order should be here in about a week But I do have my trusty kaoss pad kp2 And those xy pad setting where designed for it It is my Understanding it sends those same values Ok bear with Using the event processor plus I create 2 Settings Setting 1 map a midi event ; Control change ; 12 value y Midi Channel: 1 Map to this event : Control change; 1 value y midi channel :1 Setting 2 map a midi event ; Control change ; 92 value y Midi Channel: 1 Map to this event : Control change; 11 value y channel 1 So I program that in connect everything up And setting 1 works fine setting 2 does not So I can use the x y pad as an expression pedal Awesome first step complete But the kp2 (as far as I understand it send touching the pad 127 and not touching it 0 So touching the pad should turn the fx on and off And it does not What am I doing wrong ? It is possible the kp2 doesn't send those values I know for sure the xy pad will but can't test it for a week I looked in the kp2 manual but most manuals have extremely limited midi instructions And I'm honestly pretty new to midi The event processor plus will let me nap pretty much any midi info to any other I assume it needs to be cc to cc in this case Did I do it wrong ? My other options are Note on Note off Key pressure Program change System exclusive But it seems like cc to cc is my best bet Values can also be value y Or variable 1-8 or 0-127 I mean I could also map it to the y axis channel 13 but I don't know how that would work with just on off Basically I'm trying to use 1 axis as an expression pedal and touching the pad as bypass/ on I'm not sure if anyone has messed around with this maybe I'm the first lol Could be cool if we could figure out then One could ostensibly control the whole pedal from a touch screen on your guitar So worth it gotta figure it Out!! Please and thankyou for any advice :) Quote Link to comment Share on other sites More sharing options...
