lancegw Posted July 21, 2013 Share Posted July 21, 2013 Help! A speedy changeover at a festival yesterday, connected my HD500 using 4 cable method - plugged in, turned on... Nothing....! Ended up gigging straight into the amp. Got home and tested all leads, amp effects loop etc - they're all fine. Then tried HD500 with headphones - strong signal coming through...! So the HD appears to be working - all leads are ok - amp loop is still a poss weak link but it's a Dual Rec, built like a tank, never had dramas with it... Any ideas?? Quote Link to comment Share on other sites More sharing options...
bjnette Posted July 21, 2013 Share Posted July 21, 2013 Seems like your under a process of elimination. Try another pedal or rack effect thru the power amp to rule out your first suspect. Oh you did that. The FX loop on the HD has a send and return level. Could be that. and double check the cabling again is all I can think of. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted July 21, 2013 Share Posted July 21, 2013 some effects loop/returns won't work with nothing in the main 1/4 input.... have you tried this with a guitar cable also in the input? Quote Link to comment Share on other sites More sharing options...
evilmikehoo Posted July 21, 2013 Share Posted July 21, 2013 Well, I AM getting old and senile, but, every once in a while - when I'm rushing to get it done - and not really paying attention..........I put the cables in reverse order!! Quote Link to comment Share on other sites More sharing options...
