mdmayfield Posted October 22, 2015 Share Posted October 22, 2015 I've checked the manual and have been messing around with the Helix, but so far I can't seem to find a way to un-assign a footswitch from an effect. It's easy to assign it to a *new* effect with Replace instead of Merge, but how do you actually remove all assignments from a footswitch? Quote Link to comment Share on other sites More sharing options...
mdmayfield Posted October 22, 2015 Author Share Posted October 22, 2015 I worked around it by adding a new effect to an empty block, using Replace to assign the pedal to that effect only, then removing the effect... But that seems really clumsy and inconvenient. What's the proper way to do this? Quote Link to comment Share on other sites More sharing options...
duncann Posted October 22, 2015 Share Posted October 22, 2015 With the effect selected, hit the menu button, then footswitch assign, then set the footswitch to none. 3 Quote Link to comment Share on other sites More sharing options...
mdmayfield Posted October 22, 2015 Author Share Posted October 22, 2015 With the effect selected, hit the menu button, then footswitch assign, then set the footswitch to none. Thank you! Quote Link to comment Share on other sites More sharing options...
jaminjimlp Posted October 23, 2015 Share Posted October 23, 2015 you can then also use the joy stick to sift though the other blocks and set or clear the assignments. Quote Link to comment Share on other sites More sharing options...
Gareth1 Posted August 5, 2016 Share Posted August 5, 2016 I'm not understanding how to assign a footswitch to switch off one amp and turn another one on. Also i want to be able to turn on a whole chunk of signal chain when i change to a different amp. Will this be in snapshots, & if so, how do I do that? thanks Quote Link to comment Share on other sites More sharing options...
vioreldodoc Posted October 22, 2019 Share Posted October 22, 2019 Easy way for me: Copy block. Delete block. Paste block :D Quote Link to comment Share on other sites More sharing options...
kinger77 Posted January 7, 2024 Share Posted January 7, 2024 Im sure I'm late to this party, I figured out how to clear a CC Value foot switch. Touch the foot switch when the command center comes up turn the (first knob) COMMAND knob to none.. Quote Link to comment Share on other sites More sharing options...
