Fire hawk effects only
Davidians
Select No Amp in the Firehawk preset. Set the Firehawk Output Mode to Amp.
The simplest connection method is to connect your guitar to the Firehawk and connect the Firehawk output (mono) to your amp's guitar input. This will position all Firehawk FX in front of (pre-) your amp. If you want the flexibility of having some FX pre-amp and some post-amp you will need an amp with an FX loop (send/return) and you will need to use the 4-cable connection method. You can search this forum for details about that.
  • 2 weeks later...
Hi Silverhead...thanks for your help.
So I've tried the 2 cable like you suggested and the 4 cable....
With the 4 cable I have no control of my amps volume? I have a Mesa Nomad 45 combo. It does have a series effects loop. Can get effects working with my amps channels but no volume increase when adjusting volume.
