cacibi Posted November 2, 2015 Share Posted November 2, 2015 It seems to me with the first two firmware updates, if you want the new Factory Presets - you are instructed to hold down the switches during startup which clears all user global settings, Setlists, Presets and IR's. Wouldn't it be better just to make the new factory presets available as Setlists for download so that you could import those Setlists individually without re-setting all the global settings, user presets and IR's? Quote Link to comment Share on other sites More sharing options...
xavierb Posted November 2, 2015 Share Posted November 2, 2015 It seems to me with the first two firmware updates, if you want the new Factory Presets - you are instructed to hold down the switches during startup which clears all user global settings, Setlists, Presets and IR's. Wouldn't it be better just to make the new factory presets available as Setlists for download so that you could import those Setlists individually without re-setting all the global settings, user presets and IR's? That's the obvious way to go IMO, and also what Fractal does with the Axe FX upgrades. Not sure why Line 6 doesn't do this, maybe there's another reason. Quote Link to comment Share on other sites More sharing options...
duncann Posted November 2, 2015 Share Posted November 2, 2015 If you want just the factory setlists back, hold 7 & 8 while powering on. This shouldn't reset globals or IRs. Then load back your custom setlists, which you hopefully saved first. Then export the factory setlists for future importing. Or you can download the attached, from version 1.03 firmware. helix.1.03.factory.setlists.zip Quote Link to comment Share on other sites More sharing options...
