kensington Posted November 4, 2015 Share Posted November 4, 2015 Hi! Anyone knows if the amp+cab blocks use less cpu than 1 amp and 1 cab block? Also, is an IR more cpu heavy than cabs? Even 1024? Best, Ken Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 6, 2015 Share Posted November 6, 2015 Anyone knows if the amp+cab blocks use less cpu than 1 amp and 1 cab block? Also, is an IR more cpu heavy than cabs? Even 1024? An Amp+Cab block should use the exact same amount of DSP as separate Amp and Cab > Single blocks. Obviously a Cab > Dual block would use more. A 1024-point IR will use a little more DSP than a native Cab > Single block. A 2048-point IR will use a little more than twice the DSP. Quote Link to comment Share on other sites More sharing options...
kensington Posted November 7, 2015 Author Share Posted November 7, 2015 An Amp+Cab block should use the exact same amount of DSP as separate Amp and Cab > Single blocks. Obviously a Cab > Dual block would use more. A 1024-point IR will use a little more DSP than a native Cab > Single block. A 2048-point IR will use a little more than twice the DSP. Thanks for reply! :-) Quote Link to comment Share on other sites More sharing options...
