username19 Posted November 4, 2015 Share Posted November 4, 2015 I've had my Spider Valve and FBV mk 1 for several years, still enjoy it. Having an issue though (see pic). The FBV is lighting up multiple channels on its own and becomes inoperable (although the volume pedal still works when this happens). Unplugging the Cat5 can help "sometimes" but it does reappear. Resetting the amp seems to do the same as unplugging the Cat5. When the pedal freezes, I can still make changes on the amp itself. The problem doesn't happen every time, but I have a little hesitation when I bring it to gigs. Has anyone experienced this? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted November 9, 2015 Share Posted November 9, 2015 Have you tried a new CAT5 cable? Also check the pins on both the pedal and amp - sometimes these can be bent out of place. Quote Link to comment Share on other sites More sharing options...
username19 Posted November 10, 2015 Author Share Posted November 10, 2015 Thanks for the idea. Since my post, the problem got worse, all channels lit up, no control. This is a newer Cat5 cable (6 monthes or so), not the original one I had. I didn't try a different cable yet, however... On the amp Cat 5 insert of the amp, I did see something awry (see pic). One prong was lower than the others, and a few weren't sliding freely in the slots. I attempted to adjust the prongs with a tiny screwdriver. Same problem initially, but after reattaching the cable several times, the pedal works again. I think it's likely to reappear though. Wondering if the female end on the amp could be replaced easily? Not sure if you're able to answer that... Either way, thanks for the help. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted November 10, 2015 Share Posted November 10, 2015 You'd probably have to remove the amp chassis from the cabinet, and the jack may be hard-soldred to a board. Quote Link to comment Share on other sites More sharing options...
