sergengts Posted November 7, 2015 Share Posted November 7, 2015 HI All,wondering if any can instruct me thru,switching channels on my Royal Atlantic,I get as far as Menu/Command centre/selecting a footswitch,toggling to Ext Amp and then selecting ring,tip etc While I'm selecting its not actually changing channels,not sure if i should be seeing changes at that point,regardless I can't get it to switch any channels.BTW i have the little blue triangles above the command footswitch but no action.Where have i gone wrong? Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 8, 2015 Share Posted November 8, 2015 It should only be switching the amp when you press the footswitch. It works fine on my DT25 and Blackstar ID30 but not on my Peavey Bravo 112. Quote Link to comment Share on other sites More sharing options...
theolotman Posted January 21, 2016 Share Posted January 21, 2016 Hello, I have my Helix two days. I have several line 6 products (vetta, toneport, amplifi, variax,mobile keys) The Helix is now the flagship :) ​. But I have a little problem. My amp is a Fender 65 de luxe reverb. I want to use two knops EXT AMP to contact the reverb and the vibrato of the Fender amp. One for reverb and one for vibrato. I use a standard trs good working cable. The reverb can be on and off but the vibrato stays on (stops a part of a second) De fender amp sleef + ring = reverb off sleef + tip + vibato on I have tried several combinations but de vibrato stays on. Help me. Theo Quote Link to comment Share on other sites More sharing options...
