sherlocked Posted November 12, 2015 Share Posted November 12, 2015 Hi, I searched the forum but could not find an answer to this. The issue I am having is being able to use Midi to recall a preset and making it turn on and off. I am using a MFC-101. The way I figured out how to do it was: 1. sending a PC "on" message for the desired preset...and then.. 2. for the PC "off" - setting it to a completely DIFFERENT Preset that I set up which does not do anything. In this case a Delay patch with everything turned off and EQ flat. 3. sending a CC#11 [value=127] message to turn on the effect ....AND.. 4. setting the "off" value to an "on" value... so basically 127 for "on" AND "127" for "off." This allows the switch I assigned on the MFC to activate and turn off the effect whenever I stomp. So... my feeling is that there would be an easier way to accomplish this and that my solution was a bit "bondo & band-aids." :) Thanks for anyone's time and feedback! Rick Quote Link to comment Share on other sites More sharing options...
guyjames Posted April 30, 2017 Share Posted April 30, 2017 I haven't been able to figure out why I can't get the M9 to work with the BOss es-5 midi memory mode feature. Any guidance? Quote Link to comment Share on other sites More sharing options...
aliengtr Posted May 14, 2017 Share Posted May 14, 2017 I ran into this sissue, what if I had previous effect and m5 was on but for the enxt sound I want it off till i manually turn it on. figured it out using a soleman midi controller using the macro editor: sending a cc of #11 and then 0 or 127 to have be on or off innitially. not sure on other controllers Quote Link to comment Share on other sites More sharing options...
