wilso31 0 Posted November 23, 2015 Hey Guys I'm trying to set up my fire hawk to my my backstair ht-5r. I've connected up using 4 cable set up. guitar to guitar in firehawk out to fx return on amp. fx send to fx return on firehawk FX send to input on amp Now when I play the guitar the amp sounds are that of the presets but I want to use the valves of the amp and not all the presets what do i need to do currently the fx sounds are going through the amp and it bypasses the amps valves please help Quote Share this post Link to post Share on other sites
urbanspaceblast 12 Posted November 23, 2015 Activate the FX Loop and assign it to a switch. This is will be your Blackstar preamp. Then edit the FX Loop block and raise the mix to 100%. Quote Share this post Link to post Share on other sites
wilso31 0 Posted November 23, 2015 Will this allow me to use my distortion from my blackstar? Do I have to turn cabs off etc or will doing this bypass the amps? Thanks for reply Quote Share this post Link to post Share on other sites
urbanspaceblast 12 Posted November 23, 2015 What I described will allow you to switch between an amp model and your Blackstar by hitting the loop footswitch. The cab setting is up to you, just try some options and choose what works for you. Quote Share this post Link to post Share on other sites
wilso31 0 Posted November 23, 2015 Thanks I'll give it a go Quote Share this post Link to post Share on other sites
