Sign in to follow this
welchmann
Amplifi 75 no response dim lights
So i got the 2.0 update about 2 months ago used the amp once since then the other day i go to turn it on i get no response all the tone lights and tap lights are dim and the bluetooth light is dim doesnt connect to bluetooth or anything its not use able what the hell do i do?
Hi. You probably need to update firmware on the Amp to the latest version - 2.50 :-)
There are instructions available in this website.
Good luck.
Try powering off, then hold down volume and tone buttons and power it back on. This is a factory reset and helps me when it jams up.
i have tried everything to get it to work within my own power thats why im on the forums!
Have this problem myself when I try to save over preset 1C.  The factory reset fully recovers it (minus my desire to change the damn tones).  Did you try the volume+tap hold down on power on? (I said tone, but should be the TAP button)
