n9nu Posted January 5, 2016 Share Posted January 5, 2016 Hi Is the following interface suitable for updating my DT50 amplifiers firmware or do I need something more along the lines of a hardware interface....versus just the cables here. All I want to do is update the firmware and be able to flash whatever else is available as far as updates are concerned. I do not use MIDI for anything at this point in time. I am assuming that a straight USB to MIDI (5 pin DIN) cable (x 2) is out of the question...(w/o any hardware). Tnx Tim M-Audio USB Midisport Uno MIDI Interrface @ $26.00 or so via Amazon. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 5, 2016 Share Posted January 5, 2016 (edited) Yep that's it. Go to the MIDI devices web site to update it's software. More specifically you want to update the MidiSport first then make sure your using the latest Line 6 Monkey. Edited January 5, 2016 by Brazzy Quote Link to comment Share on other sites More sharing options...
n9nu Posted January 5, 2016 Author Share Posted January 5, 2016 Hi Great thank you for the information. Tim Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 5, 2016 Share Posted January 5, 2016 If the Midisport drives you nuts at first I've found that it likes to be connected "in/in" and "out/out" where some midi cables use the "in/out" and "out/in". Quote Link to comment Share on other sites More sharing options...
