G30 transmitter on G55 receiver?
rusirius
Hello!
-Will my G30 transmitter work on G55 receivers?
-Are the G55 receivers sold seperately?
-Is there a rackmount for the use of two G55 receivers?
-is it ok when the antennas of the G55 receivers are inside a rack?
urgently awaiting your reply! Thanks a lot!
Oli
  • 1 month later...
All Relay products will work with each other.
The Relay G55 transmitter is not sold separately.
It is not recommended to run any wireless with the antennas stuck in the back of the rack. The wireless signal can be comprised by the antenna's signal being stuck in the rack's box, and also electrical cabling running in a rack can also effect signal if touching the antennas.
I recommend our rack kit, which will bring the antennas to the front of the rack:
store.line6.com/accessories/mounts/g55-v55-rackmount-kit-w3-2.html
