Sign in to follow this
kkelly9
Volume of Quick loop recording
    I'm trying to play leads over a recorded quick loop track. The volume of the quick loop
    records at the same volume of the channel preset making it hard the hear the lead.
    I've read a bunch of posts and it seems that channel volume is the only setting that
    might help this.  (If the Master volume was not to change)
    So I was to play the lead and the rhythm (quick loop) on the same preset there is no
    way to make one louder than the other.  Do I need to create a 2nd preset (rhythm) where the
    channel volume is ... say ... 50% of the original use it for the quick loop recording
    and play leads on the "original" preset?
-KK-
You need to turn the volume down on your guitar when recording the loop, then turn it up on the guitar when playing the lead over it!  That's the way I have done it.
Unfortunately this is the only solution I found too, because the sound is greatly affected the more you turn down the volume on your guitar.
