Phillipgerard Posted January 16, 2016 Share Posted January 16, 2016 I have a G30 and I bought 2 additional transmitters. I want to have multiple guitars ready to go. How do you pair the transmitter with the receiver and how do you switch between instruments Quote Link to comment Share on other sites More sharing options...
NBell Posted February 20, 2016 Share Posted February 20, 2016 With our wireless their is no pairing process due to the 2.4 Ghz frequency we run on. With that being said, the best way to achieve this with a Relay G30 would be to have both transmitters on the same channel and have the transmitter that you are not using turned off. As soon as you power off one transmitter and power on the other (while on the same channel) it will be connected as soon as you power on. Quote Link to comment Share on other sites More sharing options...
crisvaneijk Posted September 29, 2016 Share Posted September 29, 2016 Hi Nick, I just bought a second transmitter at Thomann.de for the reason you describe; two guitars, one receiver. But the new transmitter doesn't connect to the receiver. I tried every channel, new batteries, but no signal... What could be wrong? Kind regards, Cris van Eijk Netherlands Picture of both transmitters: https://goo.gl/photos/P5WJJ3ECTehNCrZB6 Quote Link to comment Share on other sites More sharing options...
vestrum Posted January 18, 2017 Share Posted January 18, 2017 Hi Nick, I just bought a second transmitter at Thomann.de for the reason you describe; two guitars, one receiver. But the new transmitter doesn't connect to the receiver. I tried every channel, new batteries, but no signal... What could be wrong? Kind regards, Cris van Eijk Netherlands Picture of both transmitters: https://goo.gl/photos/P5WJJ3ECTehNCrZB6 Same problem here! Bought a second transmitter at 4sound in Oslo, Norway, and they had to order it, actually. Too bad it's not working... Quote Link to comment Share on other sites More sharing options...
crisvaneijk Posted January 19, 2017 Share Posted January 19, 2017 I've found the solution! TBP06 BeltpackTransmitter With transmitter off, set the Channel Select slide switch to channel 6. Turn on the transmitter. Immediately after the blue light blinks, slide the Channel Select switch completely left to channel 1 and back to channel 6. Do this 3 times total. This process must be completed within three seconds of turning on the transmitter. The blue LED will flash once to indicate that the transmitter is now in the 4-frequency transmission mode. To revert to RF2 transmission mode, repeat the above steps; the blue LED will flash twice when the transmitter is in this mode. http://line6.com/support/page/kb/_/live-sound/relay-digital-wireless/rf1rf2-mode-switching-frequencies-r130 Cheers Quote Link to comment Share on other sites More sharing options...
