mqueluz 3 Posted January 17, 2016 Can the M13 switch DT25 channels via MIDI? Quote Share this post Link to post Share on other sites
Brazzy 440 Posted January 17, 2016 I would think Yes. SInce I do it with my HD500. Quote Share this post Link to post Share on other sites
mqueluz 3 Posted January 17, 2016 I had the hd500 and I could set the midi cc message and value. I was able to change channels on the dt25. With the M13 I only see midi channel selection, no value... I have no ideia how would you set it to send the cc message with the value... Quote Share this post Link to post Share on other sites
Brazzy 440 Posted January 17, 2016 Oh I thought it was like the HD500. Maybe Colonel Forbin will confirm for you since I think he has the M13. Quote Share this post Link to post Share on other sites
mqueluz 3 Posted February 17, 2016 FYI, The M13 sends the same cc or pc messages (depending on the scene mode) that it receives. So when I plugged a MIDI cable from M13 to my DT25, I can only send those messages predefined in M13. It gets worse, as you select/deselect effects, you are sending MIDI messages that will do stuff you don't want on your DT25... So the solution I found was to purchase a MIDI Event Processor Plus. I was able to map and filter the messages I want (and don't want). I mainly use it for changing channels and a drive or volume boost. But you can actually do much more like changing the amp models, topology, etc, on the fly. Hope that helps. Quote Share this post Link to post Share on other sites
