Compatible expression pedals
Shrednoise321
On 6/1/2019 at 12:47 AM, anibalrivero said:
Please, how are you connecting it? I also have a Mooer Expline, but I can not make it work. I tried with a TS cable and a TRS to TS one, no luck.
Thanks!
After a few days of struggling, I finally got my Mooer Expline to work as a single expression pedal. I'm using a standard mono patch cable (unlike with Ocean Machine, used a TRS cable with that one) connected to the right side connector, and had to select the inverted tip polarity in HX Stomp (Global Settings --> Preferences --> Tip Polarity --> Inverted).
Afaik, this is the most one can do with the Expline, as it doesn't have a switch. Please correct me if I'm wrong!
  • 1 year later...
Hey @tombapaand @anibalrivero, I have an Expline, I connected the way Tombapa said, but the values are a bit weird, it starts pretty much at half the tilt, you know what I mean? If you press the heel, it's zero... you go down a bit, still zero... press a bit more, zero... and then halfway through it goes from 0 to 100 at full toe position.
Maybe my Mooer Expline unit is faulty? Did this happen to you?
Cheers.
Cheers.
You are posting to a thread that had it’s last comment made well over a year back.
There are so many comments about this 0-100-0% issue, it really should have it’s own “sticky thread”.
See these:
Hope this help/makes sense.
Hey @datacommando, thanks, I know how old this post is, I did my research before posting. Attaching a related comic strip. :)
I think this is not related to the "0-100-0" (or 100-0-100) issue, In my case, I'm using a normal mono cable in the right side of the Mooer Expline, as @tombapasaid. What I get is 0 until some point, not sure if it's 50% tilt, then 0-100 for the rest. I want to know from someone with my exact setup if this is normal.
