webe123 Posted January 30, 2016 Share Posted January 30, 2016 OK First off I need to tell you how my praise and worship guitar setup is at my church. Well I do not have a traditional tube amp/ pedal setup any more....I have went the high end modeling route.I use: an axe fx II (No XL) with a MFC 101 pedalboard hooked up to it. with a FRFR (Full range flat response.... EV 112P powered speaker) hooked up to that.Below that, is my MIDI guitar setup which consists of a yamaha Motif XS that I use for my MIDI guitar sounds and a Axon AX 100 Mark II guitar converter below that...I use this to convert the sounds from the yamaha Motif into my axon ax 100 mark II guitar converter and I run a 13 pin cord on my Godin ACS SA calssical guitar into my axon converter.(I use this for various sounds a guitar cannot make...such as flutes, strings, horns, etc.)My acoustic setup consists of a Fender acoustisonic amp with a LR Baggs preamp and M1 acoustic guitar pickup running into a H2O Liquid Chorus for all my acoustic guitar chorus sounds.I run the acoustic seperately to the PA on a different channel than my electrics.My guitars in the picture: are (From left to right) (1) a Godin LCS SA Classical I use for MIDI,(2) a PRS Modsern Eagle 1 Private Stock and (3) a Fender 57 Reissue strat. I run those three guitars into an ART 4 in 1 unpowered mixer (So that I can simply turn up the volume of a guitar when I want to use it, then turn it off after I am done and put it back on the stand.)On the right of the picture, is a Taylor 312 CE acoustic guitar.I have a vox wah and earnie ball volume pedal. And other than stands, cords and a fan...as well as an ipad 3, That is my setup at church. It may not be a "traditional" guitar setup, but going direct like I do serves me well in a church enviornment. Here is apic of my guitar setup.... http://i34.photobucket.com/albums/d148/webe123/000_0688_zps6759fc88.jpg QUESTION......I want to add a variax to the mix and run it through my setup with my axe fx II....BUT I use a unpowered mixer to plug the guitars into fist and THEN take one 1/4 line to the front of the axe fx II. This way....I can pickup a guitar...turn up the volume and I am ready to play. And when I am done...I simply turn off the volume and put the guitar back on the stand. NOW HERE IS MY QUESTION.....Can I use a line 6 variax XPS AB box to power my variax and run it into the mixer and then from there the mixer will go into my axe fx? This is the one I want to use http://www.ebay.com/itm/Line-6-Variax-Cabled-Power-Kit-9V-XPS-AB-Box-Planet-Waves-15-Guitar-Cable-JTV-/271742594071?hash=item3f451eec17:g:yjwAAOSwYHxWHABC And it will go into a unpowered mixer like this http://www.ebay.com/itm/ART-SPLITMix4-4-Channel-Personal-Mixer-/401057695229?hash=item5d60e6c5fd:g:xdMAAOSwCypWnj3W I may have to get another unpowered mixer just like this...as all of the inputs to this main one are filled....but what I can do is go out of one and into the other. (At least I THINK that will work....never tried daisy chaining two passive mixers together like that) If that does not work I can just get a line mixer I guess??? Then from there into the front input of the axe fx II. Will I screw something up if I try to use something like this that POWERS the variax like the Line 6 XPS AB Box? Quote Link to comment Share on other sites More sharing options...
wheelnut Posted January 30, 2016 Share Posted January 30, 2016 The only power is in the TRS connection from the A/B box to the Variax. The A/B box output (which you would connect to your passive mixer) is just a regular mono 1/4" connection, with no power. You'll be absolutely fine. Just to confirm the correct routing: Variax Standard > TRS cable > A/B box 1/4" input > A/B box 1/4" output > passive mixer > Axe FX Nice rig by the way :) Quote Link to comment Share on other sites More sharing options...
webe123 Posted January 30, 2016 Author Share Posted January 30, 2016 OK Thanks for that explanation! And thanks for the thumbs up on my rig! Quote Link to comment Share on other sites More sharing options...
