elvissideburns84 Posted February 20, 2016 Share Posted February 20, 2016 Hi, last night I tried to record through reaper but I couldn't manage to set it up. I have seen it mentioned about setting the input on reaper to the podhd500x or something but still I couldn't figure it out. Where do u change that setting? i tried changing it on the track on reaper but I couldn't see any setting for the pod. If somebody could run me through how to set it up I would be really great full. Thanks :) Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 20, 2016 Share Posted February 20, 2016 You don't make that setting at the track level. It's a global setting within Reaper - I think it's in an area called Preferences or Settings. In the Audio section you select the HD500X and its ASIO driver as your audio input/output device. To do this you need to have your HD500X connected to your computer via USB. After doing that (you may need to restart Reaper) you will find the HD500 Inputs available in the track section when you arm a track for recording. Also you should set the HD500X Output Mode to Studio/Direct. Quote Link to comment Share on other sites More sharing options...
elvissideburns84 Posted February 20, 2016 Author Share Posted February 20, 2016 Awesome :) Thanks for helping. Quote Link to comment Share on other sites More sharing options...
