Direct path switching
Dshow
As far as I know it isn't possible to directly switching between paths.
So If I want to have a patch with paralell paths and switch between them It is done for example by inserting two volume pedals.
So what's the reason for not enabling direct path switching?
You could also do it by controlling the level of the output blocks. Or if you're dealing with paths that have split blocks, you can control the routing of the split block. How do you envision "direct path switching" working?
Thanks for the reply. I have to experiment a little with that.
I guess it's just different thinking. For me it would be logical to just engage one path while disengage the other. Meaning set one input to know the other to guitar or whatever is pluged in.
