Help with assigning multi-function footswitch
thatguyguitar
Just received my Helix rack/control and I'm getting some great tones pretty quick running 4 cable mode with Mesa Mark V. I see posts saying that a footswitch can do up to 8 functions but I'm having trouble getting started with this. Is there anything on this forum (or anywhere else) that provides step by step instructions. I assume this is something you do in the command center but just not getting it.
Thanks in advance!
1. Press and hold the knob underneath the LCD for the parameter you want to control. This will bring up the Controller Assign page. You set the footswitch or expression pedal you want to control that parameter with Knob 2. Set the min and max values using Knobs 4 and 5.
2. Repeat step 1 for whatever other parameters you want to control.
3. If you want to make a custom label for the scribble strip associated with the footswitch you're assigning things, hit the button with three lines on it next to the save button and go in the Command Center. Navigate over to icon of the footswitch you assigned stuff to and select "Customize" by hitting Knob 6.
