Ruben40 Posted March 1, 2016 Share Posted March 1, 2016 I use both the internal and an external expression pedal. When I change the preset, then the actual position of my internal ex-pedal is used as start value in the preset.This is behaviour is set in the global setting. (footswitch)But when I use the external expression pedal, that pedal start value is always set to the minimum value independent of the actual position of the pedal. Therefore I have to move the pedal.I want to use the external pedal for adjusting my global volume, but here I have always to touch the pedal to get my desired volume.Can anybody confirm this ? Thank you Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted March 1, 2016 Share Posted March 1, 2016 I use both the internal and an external expression pedal. When I change the preset, then the actual position of my internal ex-pedal is used as start value in the preset. This is behaviour is set in the global setting. (footswitch) But when I use the external expression pedal, that pedal start value is always set to the minimum value independent of the actual position of the pedal. Therefore I have to move the pedal. I want to use the external pedal for adjusting my global volume, but here I have always to touch the pedal to get my desired volume. Can anybody confirm this ? Thank you What FW are you running? I do find on SOME patches, that I have to rock my pedal because even though it's set to global, sometimes one of the pedals gets "fiddly". I chalk it up to the fact that Helix is trying to figure out what my three COMPLETELY DIFFERENT expression pedals are every time I turn it on. Maybe I should be calling this a bug. It doesn't affect me much because I am likely to use only one patch for an entire set of music, but you are not alone. Quote Link to comment Share on other sites More sharing options...
Ruben40 Posted March 1, 2016 Author Share Posted March 1, 2016 What FW are you running? I do find on SOME patches, that I have to rock my pedal because even though it's set to global, sometimes one of the pedals gets "fiddly". I chalk it up to the fact that Helix is trying to figure out what my three COMPLETELY DIFFERENT expression pedals are every time I turn it on. Maybe I should be calling this a bug. It doesn't affect me much because I am likely to use only one patch for an entire set of music, but you are not alone. I use the 1.06.5 FW. I will test, if all presets are affected. Quote Link to comment Share on other sites More sharing options...
