rythmoemos Posted March 16, 2016 Share Posted March 16, 2016 My amplifi 150 sounds distorted on any clean tone when using a high output guitar such as Les Paul or PRS. No matter what I do the sound is not really clean but instead sounds kind of crunch. I did everything like picking up clean amps with the drive to 0. It really made me go back to my other amps. Terrible problem. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 17, 2016 Share Posted March 17, 2016 Don't know that there's much more you can do about that, and not sure it's a 'problem' unique to the AMPLIFi. That's kind of the nature of high gain guitars. That's why players normally use a Tele or Strat when they want really clean tones (e.g. with a Fender amp), and why you see LPs used mostly with Marshall or hi-gain amps. Clean vs. dirty - there's equipment for each. Mixing them gives you a good middle ground, but if you want really clean you typically don't use a Les Paul. And if you want really dirty you typically don't use a Telecaster. Quote Link to comment Share on other sites More sharing options...
rythmoemos Posted March 17, 2016 Author Share Posted March 17, 2016 Don't know that there's much more you can do about that, and not sure it's a 'problem' unique to the AMPLIFi. That's kind of the nature of high gain guitars. That's why players normally use a Tele or Strat when they want really clean tones (e.g. with a Fender amp), and why you see LPs used mostly with Marshall or hi-gain amps. Clean vs. dirty - there's equipment for each. Mixing them gives you a good middle ground, but if you want really clean you typically don't use a Les Paul. And if you want really dirty you typically don't use a Telecaster. Quote Link to comment Share on other sites More sharing options...
rythmoemos Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks for the reply.The thing is that on my flextone xl that I have this does not happen.I can get excellent really clean sound with any guitar. Quote Link to comment Share on other sites More sharing options...
