Helix + Variax 700 ?
mykejb
It is not supported but it partially works with my old Variax 300. The power is fine and communication between Helix and the V300 seems OK. I can store V300 model settings in the Helix preset and they are recalled correctly, resetting the V300 model as prescribed. However the settings must be made using Helix. V300 to Helix communication does not work for me. If I manually select a V300 model the change is not properly captured or stored in Helix.
Since Helix <-> Pre-JTV communication is not supported it is possible that your experience might be different. Give it a try to see whether you can find an acceptable way to work things.
