DavidBurt Posted April 1, 2016 Share Posted April 1, 2016 I am using a Mac OS El Capitan and have more than 90 IR's loaded into the Helix Impulse list. Is there a way to copy the complete list at once so that I can save prior to updating the firmware? Thanks Quote Link to comment Share on other sites More sharing options...
EdwinV Posted April 1, 2016 Share Posted April 1, 2016 You can select them all by clicking on the first, hold down the "shift" key and clicking on the last. Then push "export". However, if you're having the same problem with the Helix app (1.04 or 1.10) and Mac OS X 10.11.4 as I do, the Helix app will freeze before the export is ready. So I did them 1 by 1 instead. I've understood that this is a problem of OS X 10.11.4 (at least). Somehow, I can record perfectly through the USB interface and also the Line 6 updater works fine, but the Helix app cuts out every time (sometimes no connection, sometimes the connection is lost after a while). Either directly in a USB slot or through a (powered) USB hub, it makes no difference. It does work under Windows 10 though ... :( Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 1, 2016 Share Posted April 1, 2016 In the app you can export all IRs in one operation. This creates individual wav files in a folder on your computer. However I am not sure that this operation retains the critical association between filenames and IR slot number in Helix so the operation may not be reversible. I suggest changing the filenames of your IRs before exporting to include the slot number as a prefix to the filename. That way you can manually import the individual IRs to the correct slot. Quote Link to comment Share on other sites More sharing options...
DavidBurt Posted April 1, 2016 Author Share Posted April 1, 2016 In the app you can export all IRs in one operation. This creates individual wav files in a folder on your computer. However I am not sure that this operation retains the critical association between filenames and IR slot number in Helix so the operation may not be reversible. I suggest changing the filenames of your IRs before exporting to include the slot number as a prefix to the filename. That way you can manually import the individual IRs to the correct slot. Thanks. I will try this. Quote Link to comment Share on other sites More sharing options...
DavidBurt Posted April 1, 2016 Author Share Posted April 1, 2016 You can select them all by clicking on the first, hold down the "shift" key and clicking on the last. Then push "export". However, if you're having the same problem with the Helix app (1.04 or 1.10) and Mac OS X 10.11.4 as I do, the Helix app will freeze before the export is ready. So I did them 1 by 1 instead. I've understood that this is a problem of OS X 10.11.4 (at least). Somehow, I can record perfectly through the USB interface and also the Line 6 updater works fine, but the Helix app cuts out every time (sometimes no connection, sometimes the connection is lost after a while). Either directly in a USB slot or through a (powered) USB hub, it makes no difference. It does work under Windows 10 though ... :( Thanks. This helps a lot. I will try this later. Quote Link to comment Share on other sites More sharing options...
DavidBurt Posted April 1, 2016 Author Share Posted April 1, 2016 You can select them all by clicking on the first, hold down the "shift" key and clicking on the last. Then push "export". However, if you're having the same problem with the Helix app (1.04 or 1.10) and Mac OS X 10.11.4 as I do, the Helix app will freeze before the export is ready. So I did them 1 by 1 instead. I've understood that this is a problem of OS X 10.11.4 (at least). Somehow, I can record perfectly through the USB interface and also the Line 6 updater works fine, but the Helix app cuts out every time (sometimes no connection, sometimes the connection is lost after a while). Either directly in a USB slot or through a (powered) USB hub, it makes no difference. It does work under Windows 10 though ... :( Thanks EdwinV. Worked perfectly without the Helix freezing. I have OS XEl Capitan 10.11.3. Quote Link to comment Share on other sites More sharing options...
DavidBurt Posted April 1, 2016 Author Share Posted April 1, 2016 In the app you can export all IRs in one operation. This creates individual wav files in a folder on your computer. However I am not sure that this operation retains the critical association between filenames and IR slot number in Helix so the operation may not be reversible. I suggest changing the filenames of your IRs before exporting to include the slot number as a prefix to the filename. That way you can manually import the individual IRs to the correct slot. You were correct! I have only used 5-6 of the IR's so it wasn't too much work matching them with the patches after updating the firmware. I will re-label them next time. As for the editor - Wow! It looks and works great. Keep up the good work Line 6. Quote Link to comment Share on other sites More sharing options...
EdwinV Posted April 1, 2016 Share Posted April 1, 2016 That's great 👠Quote Link to comment Share on other sites More sharing options...
