Bradburn1 Posted April 3, 2016 Share Posted April 3, 2016 Hello, Could anyone help me with this please . Just connected my JTV to my PC using the supplied interface with the intention of playing around with Workbench for the first time. When I came to disconnect my interface cable from my Variax I was unable to remove the connection. I don't have any trouble removing the Variax to amp connection , I simply press down on the metal clip and whilst holding it down just pull out the plug. That however does not work with the interface cable- I just can't move it. Any ideas anyone ?. Obviously I now can't use the Variax until I get this damned thing out. Thanks, Derek B. Quote Link to comment Share on other sites More sharing options...
snhirsch Posted April 3, 2016 Share Posted April 3, 2016 I've seen problems of this sort occur when a cord-mounted connector is stepped on and bent slightly out of round. Have you tried sitting the guitar on a table where you can hold in the release tab and wiggle the connector back and forth as you try to pull it out? Unless the release clamp is outright broken it should move. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 3, 2016 Share Posted April 3, 2016 Some of the old cables did not have the release tab on the Cat5 connector removed. Then it's a Bear to get the thing to release. Quote Link to comment Share on other sites More sharing options...
Bradburn1 Posted April 4, 2016 Author Share Posted April 4, 2016 Hello, Thanks to those who replied to my query regarding me being unable to remove the interface cable from my JTV. After much jiggling and swearing at it I finally got it out. Regards, Derek B. Quote Link to comment Share on other sites More sharing options...
snhirsch Posted April 4, 2016 Share Posted April 4, 2016 Great! Based on Charlie's post it would be a good idea to take a close look at the RJ-45 (plastic plug in the connector that was trapped). If the release tab is still there, consider disassembling the connector and breaking it off. The release tab is needed only when the RJ connector is alone on the end of the cable. Quote Link to comment Share on other sites More sharing options...
