ryanneal Posted April 6, 2016 Share Posted April 6, 2016 Hi What is the best method for setting the output levels on the L3T and L3S, vs the output level on the M20D I am not sure. Should I set the speakers at 75%, then use the m20D to set final room level? Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted April 6, 2016 Share Posted April 6, 2016 Master colume knob on L2t/m L3t/m and L3s should *ideally* be set to their 12o'clock position (where there is a notch in the sweep for the control when the speakers are connected to an M20d using L6Link Then just control volume via the M20d. Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted April 6, 2016 Share Posted April 6, 2016 I run mine as SiWatts suggests. There is plenty of head room from the board. It's unlikely at any inside gig that you will even get the mains on your M20d up as high as -10db. I got mine up that high once but was in a huge banquet hall. Most pubs I'm running at -15 or -16db. So the centre detent position is plenty of horsepower. Quote Link to comment Share on other sites More sharing options...
ryanneal Posted April 22, 2016 Author Share Posted April 22, 2016 Thanks guys Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted April 22, 2016 Share Posted April 22, 2016 I run mine as SiWatts suggests. There is plenty of head room from the board. It's unlikely at any inside gig that you will even get the mains on your M20d up as high as -10db. I got mine up that high once but was in a huge banquet hall. Most pubs I'm running at -15 or -16db. So the centre detent position is plenty of horsepower. LOL, you're not giving it enough oomph then litesnsirens ;-) We run at about -5db but scale the rig to suit the venue: <100 capacity: 2 x L3m 100<150 capacity: 2x L3m + 1x L3s 150+ capacity: 2x L3m + 2x L3s Adding the subs in increases the headroom quite significantly to the extent that our FOH level on the M20d is rarely anywhere other than I the range of -7.5db to -2.5db, most typically at around the -5db mark. When I'm doing wet hire with the rig (I regularly do for a SKA band) they like it loud (as do their crowds) so it might get pushed up a little, but I've not yet got to 0db (or above!) Quote Link to comment Share on other sites More sharing options...
litesnsirens Posted April 25, 2016 Share Posted April 25, 2016 Perhaps my trims are set higher across the board but if I try to run the mains hotter than what I am doing people's ears will start to bleed... Quote Link to comment Share on other sites More sharing options...
