Odd Behavior -- with Mic on Certain amp+cabs and cabs
davidb7170
Odd Behavior -- with amp + cabs and cabs that load up with the 421 Dynamic Mic model. These are:
2x12 Double C12N
2x12 Mail C12Q
2x12 Silver Bell
4x12 WhoWatt
4x12 Green Back 20
It shows the 421 Dynamic Mic as the one that loads with these, but when switched away auditioning mic models, then come back to the 421 Dynamic it sounds very different - more treble like the other Dynamic models in that first group. If you save the preset and reload it, it sounds like it did when first loaded - identical to the 121 Ribbon MIc model. I don't particularly like the 421 Dynamic sound, and usually switch to something else, but if you would like to use it with those models, it will always load up showing the 421, but sounding like the 121 Ribbon.
As a test I loaded a cab not in the above list that 421 Dynamic is not normally loaded with, then changed it to the 421 Dynamic and saved. When I reloaded the patch, the normal sound of the 421 Dynamic was there, not the 121 Ribbon, so it appears to only affect the cabs in the above list or the amp+cabs that use those in the list above.
I don't know if this is a new bug, or if anyone else has found this.
I've been chunking through all the models and cabs to find my favorites and see the differences between the amps, cabs and mics, so I set up a "Test Bench" set list for experimenting with the sounds.
Side note - as I was going through the list of cabs finding the ones that load with the 421, my Helix glitched on me -- everything FX, Amps, ALL blocks on the top path disappeared. I was in my "Test Bench" set list, so I loaded my normal gigging set list and everything on those top path's were gone as well. when I re-booted the Helix, the patches rebuilt, with the count-up, and came back with the top paths back in place. That's the first glitch like that in these most recent set of firmware(s) that I've had. Has anyone else noted this behavior?
Dave.
