Aceaj78 Posted April 16, 2016 Share Posted April 16, 2016 I had the dreaded squeaky pedal and I fixed it very easily, I loosened the tension bolt with the wrench until the pedal was real floppy. I took a knife and coated the end with grease. I lifted the pedal up and went from thr toe end in underneath and slide the knife between the bushing and worked the grease in. I did the same on the outside. I worked up and down, tighted the bolt and it is quiet now. It took 5 minutes. 2 Quote Link to comment Share on other sites More sharing options...
jaminjimlp Posted April 16, 2016 Share Posted April 16, 2016 nice Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 16, 2016 Share Posted April 16, 2016 I had the dreaded squeaky pedal and I fixed it very easily, I loosened the tension bolt with the wrench until the pedal was real floppy. I took a knife and coated the end with grease. I lifted the pedal up and went from thr toe end in underneath and slide the knife between the bushing and worked the grease in. I did the same on the outside. I worked up and down, tighted the bolt and it is quiet now. It took 5 minutes. Excellent, definitely preferring this method to opening the chassis! Quote Link to comment Share on other sites More sharing options...
Ka5par Posted April 16, 2016 Share Posted April 16, 2016 Yeah, same thing knife or ruler, toe or heel:http://line6.com/support/topic/18575-line-6-staff-squeaky-expression-pedal-answer/?p=144718 Quote Link to comment Share on other sites More sharing options...
MattHamner Posted February 18, 2018 Share Posted February 18, 2018 Line 6 has a tutorial for removing the squeaky expression pedal. https://helixhelp.com/2017/06/18/tip-fix-that-squeaky-pedal/ Quote Link to comment Share on other sites More sharing options...
