Ka5par Posted April 19, 2016 Share Posted April 19, 2016 One issue with it is the polarity, that doesn't bother me that much as it can be reversed in the controller assignment.But it seems to have a logarithmic taper, or have I got it wrong?It starts with a very gradual increase and skips quite a lot values at the end of the travel.I use gain blocks at the beginning of each patch as the output from my instrument is very low into the returns and thus don't have the log / lin option.Is there a way to make it linear other than swapping the pot? Maybe a feature request is in order, to make a global setting for the external pedal? Or it might be better to have the option to choose different curves at the place where you assign the pedal to a parameter on a per assignment basis? Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted April 19, 2016 Share Posted April 19, 2016 I have a Moog ep. Same problem. Its most likely the pot value as you feared. I think i may just get the line 6 ep instead of trying to mess with it. Quote Link to comment Share on other sites More sharing options...
