Remind me again how to edit the scribble strip for a multi footswitch
zooey
I had an idea to a 'Higher' footswitch, which jacks up a bunch of unrelated footswitchable blocks, regardless of what they do, or what parameter(s) need to be changed how. I've got it set up and working fine, but I can't figure out how to edit its scribble strip text.
I have another footswitch that toggles two blocks at once (no controllers) where I was able to change its scribble lable, but either I don't remember how, or it's different when parameters are assigned to the footswitch, not blocks, or when parameters from multiple blocks are assigned, or something. When I try to edit it, it seems to be cycling through the labels for the single-assignment footswitches that toggle the fx the Higher switch is supposed to turn up, not the label for the multi-controller switch. If it's not clear what I meant by that, I'll try again.
So remind me, how do you edit the scribble strip for a footswitch with multiple controller assignments?
So, related, kinda... Is the only way to customize the scribble strip for a footswitch that only changes parameters to temporarily assign it to turn a block on and off, hit Customize from there, then remove the block on-off assignment? I can't find any other path to that Customize screen for that case.
