G70 from L6 direct (Reverb.com)
ColonelForbin
https://reverb.com/item/1577618-line-6-relay-g70-guitar-wireless-system
$400
Very tempting! I already have two of these, so, will pass on this.. Great wireless though! Love 'em.
Cool little side note: one transmitter can transmit to two (or more) receivers simultaneously!
I have one wireless set up with my Helix, the other with my stompbox pedalboard; and it's pretty cool to be able to play through two rigs at the same time without using any extra cables!!! Easy way to totally avoid noise, hum, ground loop, etc.
  • 1 month later...
$400
Wow! Even those who simply mention the G70 drop out!
  On 6/18/2016 at 7:24 AM, Tboneous said:
Problems with dropouts with your G70?
None; no dropout problems with either of mine! though doing the firmware update is a must-do, if it's not already up to date.
Picked up a tip from the Helix Facebook user group, got these Levy's wireless holders from Sweetwater. The little metal clips that come attached to the G70 transmitters are not very robust and I tended to keep knocking them loose.
http://www.sweetwater.com/store/detail/BeltpackHold
Thanx for the reply! You are all over this forum with in depth advice and tips. When I didn't hear from you, I got worried!
