botamis Posted May 10, 2016 Share Posted May 10, 2016 Has anyone had luck using Virtual Machines to run Win XP 32-bit? I'm able to Re-Flash MCU when the pedal is started in emergency mode but once I click Reset MCU and exit, the usb device is no longer recognized by Windows 10 and therefore won't forward to the VM. Has anyone got this to work? Thanks, Bart Quote Link to comment Share on other sites More sharing options...
deltalejo Posted May 30, 2016 Share Posted May 30, 2016 Hello. Which virtual machine are you using? I'm using Virtualbox, on which I've installed Win XP SP3 32 bits, on Debian Jessie and all works fine. I also recommend you to read my post http://line6.com/support/topic/17952-improved-tcddk-template/. Maybe it can make working on the TCDDK easier and it enable some useful things. Thanks. Quote Link to comment Share on other sites More sharing options...
