billbassler Posted May 13, 2016 Share Posted May 13, 2016 Are these instructions correct? The "NOT already updated Helix's firmware to 1.12" scenario link is to 1.06 and 1.10 Release Notes. Does the Check the Beta box comment apply to both installation scenarios? Please try to make upgrade instructions as simple and straight forward as possible. I shouldn't have to study the instructions or guess. A couple of links to exactly what I need to install should do it. If you have already updated Helix or Helix Rack’s firmware to 1.12: 1. Install the 1.12 Editor update, available at http://line6.com/software/. Check the “Beta†box. If you have NOT already updated Helix/Helix Rack’s firmware to 1.12, please follow the instructions below: 1. Shut down all Line 6 software as well as any software that streams audio, including, but not limited to: iTunes, Spotify, DAWs, etc. 2. Use your CURRENT EXISTING Helix application to back up all of your presets and IRs. If you’re running Helix FW 1.06 or 1.06.5, your current Helix application version should be 1.04. If you’re running Helix FW 1.10, your current Helix application version should be 1.11. 3. Quit the CURRENT EXISTING Helix application and download and install the NEW Helix editor (1.12), available here: http://line6.com/software/ Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 13, 2016 Share Posted May 13, 2016 Yes the 'check beta box' applies to both. Both links are identical, leading to the software downloads page where you specify the desired download. Quote Link to comment Share on other sites More sharing options...
