roscoe5 Posted May 15, 2016 Share Posted May 15, 2016 Mixed up a few of the previous Mesa Recto 212 IR's with the new Mesa Triple Recto amp (MTR) with AKG D112 mic IR, resulting in a nice 3D sounding set for different corresponding Helix amp types in a single IR to save Helix processing resources. MesRec212_Mix_ MTR_MV.wav- MTR (6L6) D112 mixed with Mark V (6L6) SM57 MesRec212_Mix_ MTR_STL.wav - MTR (6L6) D112 mixed with Stiletto (EL34) SM57 MesRec212_Mix_MTR_290.wav - MTR (6L6) D112 mixed with Simul 2:90 (6L6) SM57 MesRec212_Mix_MTR_2020.wav - MTR (6L6) D112 mixed with Mesa 20/20 (EL34) https://www.dropbox.com/sh/h5ky6jrpmb6blfs/AACgZuRfOPpN-NtrRsmolUVia?dl=0 You'll probably want to set the IR Block High Cut to 7,000-10,000Hz on these. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted May 16, 2016 Share Posted May 16, 2016 I'll give 'em a shot, thanks. Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted May 16, 2016 Author Share Posted May 16, 2016 I'll give 'em a shot, thanks. Sorry, forgot to mention that you'll probably want to set the IR Block High Cut to 7000-10,000Hz on these. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted May 17, 2016 Share Posted May 17, 2016 Very nice job man!!! I really like them. I played with the 4 you posted above for about an hour last night with several different guitars and patches. Quote Link to comment Share on other sites More sharing options...
roscoe5 Posted May 18, 2016 Author Share Posted May 18, 2016 Cool! Glad you like them. The 10 IR's in that folder are really the only ones I am using at the moment with Helix amps of similar power tube types. Never thought I could get so many different usable sounds out of a Recto 212. It's surprisingly a really versatile cab. I'm surprised I haven't seen more of the pro IR guys do more with different tube power amps, along with the mics and cabs. I guess that's just another variable that would expand the IR list by that factor. I did take some IR's of just my Mesa 2:90 power amp only. I tried mixing those with the solid state 3 Sigma "b" IR's, which sounded really good. The 3 Sigma solid state "b" IR's didn't sound that great in Helix by themselves to me, and the "a" IR's made with the Peavey 5150 weren't quite my taste either. Two IR's eat up too much processing for me. Maybe mixing a power amp only IR with a "sterile" SS cab IR is ta good flexible solution. Maybe I will try making some pure solid state IR's of my own. I believe my Mesa M9 bass amp power section is pretty flat. Gotta watch the wattage though at 320W into 8 ohms. Poor tube amps...IR's are about the only use they are getting these days with Helix in the stable. Quote Link to comment Share on other sites More sharing options...
