Helix as multi FX unit with dual amps - 2 x Friedman BE100's
pdkellett
Line 6 team - I just wanted to congratulate you all and say what an awesome piece of kit this is.
I used to use a G-System but those days are now dead and buried.
The versatility and flexibility and transparency of this unit is phenomenal - especially when using this in 7CM with two Friedman Brown Eye's in Stereo where Loop 1 goes to left BE pre-amp section, Loop 2 goes to right BE pre-amp section. The tone of my Friedman just oozes through wonderfully. And all of this at this price point too!
Its so much better than the G-System in terms of tone and transparency its amazing. Not to mention the flexibility and ease of use.
I did a lot of research online before buying and couldn't quite find enough reviews about using it as an FX unit only - so thought I'd post this for others looking for info.
I considered the FX8 too but made the plunge for this and will not be looking back. The FX8's routing flexibility is a long way behind the Helix. I hear its FX are better - if so they must be mind blowing as I can't really fault the Helix.
The amp modelling is not as important for me - but I do think these can be made a little better. I have a Kemper too and in my opinion it's still superior - the amp tones just sound less digital. But obviously a Kemper is not a modeller.
The only aspect a G-System still wins on (which is surprising) is the amp relay switching - with its dual outputs that allowed full switching of 2 amps independently.
I look forward to lots of updates to this unit though - more FX, and possibly better / more flexible reverbs.
Otherwise - this thing is about as good as it gets as a multi FX unit for real amps - especially if you have 2 in stereo. I think you should promote this aspect of the unit more as, in my opinion, this is its true strength until the amp modelling is made just a little bit more realistic.
I agree!
I'm really loving using my Helix in stereo (and in 7cm) with two of my guitar amps.  The routing options you have in Helix are just awesome - as is the UI and the FX. I have to say the modelling is pretty good.  I have dialled in Helix amps to mimic the preamp section of my amp, and on occasion after A/Bing between them for a bit whilst I tweak the Helix one I end up playing away thinking I'm on the real amp and when I look down it turns out I was using a Helix amp!
Running my Helix mono currently with tube amp return in and a V30 cab and love it.
When I was trying to integrate my Mesa amps 4CM I used an RJM amp gizmo midi amp switcher. Helix's 2 switch amp control wasn't enough.
Now it's Helix amp models only into the power section of the amp.
