No Mic signal
stevejojo
I set myself up to record via the Mic input on my helix rack. I am using a condensor mic and I have the phantom power set on.
I get the light on the mic, I have input set to Mic but I get no signal whatsoever.
I've seen a couple of threads suggesting the there may be issues with mic preamps, does it sound like I have a faulty unit?
You might want to try a simple path just testing the mic output through a speaker first to remove the recording setup as a possible point of failure, and of course check to make sure the ouput block is set correctly to the output you are using (sorry in advance if you already tried this). You may also want to check your level in the "Mic In Gain" in Global Setting's In/Out parameters. When you are recording the Mic output will be going to USB 1/2 by default if for instance you have "Multi" set for the ouput.
